H2 New tow vehicle throttle not working.
My new TV 07 Hummer H2 was advertised as run an drive it starts w/ jump box (so battery is weak and probably has an effect on the electronics receiving correct readings) & runs
However won’t drive.maybe if she was on a smooth drive she would forward but shes on crused rocks, she did move backward.
After ignition all she doe’s is idle when I give it throttle she stays at idle.
I looked closely an observed someone attempted to splice 4 wires at the fly by wire throttle body.also # 2 cylinders fuel injector plug was disconnected.
When she was ideling I pressed a few of these twisted together wire an she surged a tad.
I’m sure it is throttle related bc she only idels, does not respond to the pedals input, dam what happened to just cables dam.
Anyway was unable to drive H2 home so I’m forced to hire a transporter.
I’d like to know if I should buy a small OBD2 scanner to diagnose w/ codes the throttles pedal & throttle bodys sensors,
https://www.amazon.com/gp/product/B01G5EA74I/?tag=gmtnation-20
or can I get by w/ a decent multimeter which I already have?(just need some decent test leads this https://www.amazon.com/gp/product/B06XYNF47M/?tag=gmtnation-20
If the TBs electric engine is rotton can it be replaced or must the whole throttle body be replaced?
Thanks Guys for advice.
