Ace1875 said:So it's variable vacuum line?
Ace1875 said:No not the manifold vacuum the fuel pressure regulator vacuum.
Ace1875 said:I think I have a bad hose cause it's very very loose. And after replacing everything I can think of, the rpm between 1000-2000rpms are not so smooth while driving.
I capped the regulator and on my autel ds708 I noticed that my regulator was at max PSI so I reinstalled that little hose and slight tape around it.
I noticed that the K&N CAI replaces the resonator. What do they do to that regulator hose?
Wooluf1952 said:There should be a connection in the CAI tube for FPR hose.
There should also be a connection for the PCV hose.
Ace1875 said:yeah i saw them. are they hollow or closed at the intake tube? anyone have one?
Ace1875 said:I capped the regulator and on my autel ds708 I noticed that my regulator was at max PSI
the roadie said:Are you missing your hose or something? Why even ask the question? In my experience, if the hose falls off, your vacuum is messed up and idle RPM rises to 900 and things aren't right.
matthewcc17 said:So i hooked up a fuel pressure guage, and ran the engine. The pressure sat at 56psi at idle (600rpm) and while I rev it. I pulled the vacuum hose off with no change in pressure or rpm. Still 56 psi. I blew in the hose to the fpr with no change. I sucked on the hose to the fpr and the fuel pressure dropped down to 48psi.
From what I have read, the fuel pressure should increase when there is more vacuum. Does this mean that my fpr needs to be replaced?
Wooluf1952 said:I believe it is just the opposite.
Vacuum is highest at idle so the FPR lowers the fuel pressure.
When you accelerate the vacuum is lower and the FPR allows full fuel pressure.
matthewcc17 said:Ok. This vacuum line is connected to the intake tube.
The air filter provides restriction to air movement.
At idle only a small amount of air volume is needed for the engine to run. So with less flow through the air filter, there would be minimal to almost no vacuum in the intake tube (only slightly lower than atmospheric pressure).
Under WOT a very high volume of air is needed for the engine to produce power.
With a this great demand for air, the air filter is now creating more restriction to this high volume demand, increasing the amount of vacuum (lower pressure) in the intake tube.
A simple test of removing the air filter and holding your hand over the end of the intake hose to simulate the air filter (just leave a small hole) while idling then have a friend or significant other rev the engine and the difference can be felt.
How could it possibly be any other way?
Wooluf1952 said:You are probably right. I was thinking of engine vacuum, and that's measured after the throttle body.
T
I think I figured out what the problem is I had the same problem. I'll show you the little hose was connected to the wrong port there is a port down to the right .I will upload the pictureof for you.I get the same problem. I get little to no vacuum out of that little hose. Could the resonator, were the vacuum comes from be dirty or clocked.
