Front left axle shaft leak
billcare4228
2
Foxhome, MN
Hi all. 05 9-7x 4.2 still have the factory awd. Don’t actually mind it because I drive it and am careful when I see it could engage.
Anyway, I just went through the front end, control arms,axle shafts and seals and ball joints etc... all because the drivers side axle shaft was leaking. Now it’s leaking again. There is play in the shaft. Is this because of a bad bearing where the shaft goes ito the diff? I’m a little peeved about this... thanks for you help!
Welcome to the Nation! Quite possible if it was leaking for some time the lube got low and the bearing got damaged. You'll have to pull the axle and inspect. The axle might also be damaged since the bearing rides on it.
TJBaker57
2,907
Colorado
Isn't there some form of bearing preload adjuster behind the seal on the drivers side of that front differential? Could that be incorrectly positioned and would that lead to a leak?
Mektek
656
FL
Over time with wear and tear there will be some play on the axle shaft. As long as a flexible seal is there it won't leak, but if you have severe damage then even a new seal will self destruct. I changed the seal on my 220k mi diff over a year ago and it's still OK.
fhendsbee
