- Aug 7, 2013
- 76
I have a problem and I have no idea where to start:
I've had this Bravada for about 3 months now. About two weeks after we got it, on the way back home from vacation, the front end started binding when turning sharp at low speed. Like when pulling into a parking spot or up to the gas pump. This being my first 4WD I thought maybe the 4WD was kicking in for some reason. The next morning I got in it to drive it and try to figure it out, but it had "fixed itself".
The problem didn't reoccur until just a week ago. Now it does it all the time. I've been trying to find posts with similar issues, but have been unable to find anyone who had the same issue. (maybe I am just horrible at searching!) Now the wife just called me and said it is making a kind of metal on metal "howl" while turning also.
Like I said, my first thought was that the 4WD was kicking in. But after paying closer attention, they front tires don't seem to be pulling. It's more like the brakes are engaging, or the front tires are at the wrong angles to travel smoothly through the turn. There is enough resistance that you have to get on the gas to get through the turn. And if you are on gravel, or there is some sand on the concrete, the back tires will slip a little from the force needed to push the vehicle through the turn.
I am pretty comfortable working on engines, but have never done any work on anything in the drive train after the engine (other than brakes). Add to that my total unfamiliarity with 4WD, and I just have no idea where to start looking. If anyone can give me some ideas on what to look at first, I would appreciate it!
It's a 2002 Olds Bravada with 107,000 miles. I did check the air pressure in the tires, and the tires all have plenty of tread and all are worn evenly.
