Hi guys
I just changed my battery two weeks ago and after that all hell broke loose.
All lights are flickering almost all of the time and if i turn the high-beams on i get a insane power spike or something.
Everything dies/restarts for a fraction of a second engine dies but continous to run if i am driving but dies when in idle.
Instrument cluster behaves as if i shut of the ignition or more like i had disconnected the battery, i get thumps in the speakers even if the radio is off.
I have looked at the battery connections and they seem to be good, i have been jerking the positive and negative wires really hard when the engine is running with no result.
One time when i hit the HB at idle in the driveway everything just died, key stuck in ignition everything dead EXEPT my acc outlets!?!?.
I then popped the hood and everything comes back again.
Yesterday it started to powerspike/die on me if i only put the foot on the brake.
The flickering is usually rather fast in frequency but could sometimes be as slow as once a second.
I changed my battery because its been bad for quite a long time and i also have problems with occasional draining problems in the past (i hope).
Sometimes it works just fine but that seems to be worse every week.
Im thinking maybe this is the alternator and /or the regulator that is causing this.
I have been searching both here and at the OS but not found anything like this, just flickering lights but not this spike/die thing.
Anyone have any ideas??
I should try to make a video later on.
//Janne
//Janne
