Flexplate replacement recommended?
jmonica
388
Hamburg, NJ
Hi. Do I need to replace the flexplate if I’m installing a used transmission in my ‘06 Envoy SLT? The existing FP has about 159k miles on it. Thx
The vast majority of flexplates last the lifetime of the truck. There have been very few that had cracked but the one I know of here was severely abused. My 02's flexplate out lasted two engines.
Just give it a good inspection as well as the rear main seal while you're there. If they're good, leave them alone.
7,832
Some additional Food For Thought on what might be involved with Flex-Plate Failures:
jmonica
388
Hamburg, NJ
Ok awesome. I very much appreciate your reply friend. Thank You
seanpooh
461
After my trans blew up two years ago, it was rebuilt. A few days later my original flex plate cracked. I put a used one in and that one cracked a few days later. I got a new ACDelco one and it's been 2.5 years on it now. Just a personal experience story.
jmonica
388
Hamburg, NJ
Thanks for sharing your experience. I was just about convinced that I would be fine without replacing it, and now I am sure. That I am going to replace it. The location that I have to work on the vehicle is about as inconvenient as it could be and I don't have anyone I know who can or would lend a hand, so I'd rather not have to repeat pulling and replacing the trans if I can avoid it for $60. Thank You again. Jim
jmonica
388
Hamburg, NJ
So after all was said and done, I inspected my plate and have decided not to replace it. Mostly due to financial issues. I found and replaced a boat load of other parts that were either rusted or broken during the swap. The plate looked good so I am going to have to take the chance of sticking with the old one. If I ever get the transfer case in I will report back as time goes.
Tcwest38
