Find a G80 for the rear end or do an aftermarket upgrade like Powertrax, etc...?
c good
541
Hi All,
The 2002 Envoy 4x4 is still running perfectly after the PCM was replaced. Almost 3000 miles now. All is good. Now that I will be keeping it I'm thinking of upgrading the rear differential. It is currently the stock 3:42 GU6.
So...a few questions....Did they make the G80 in a 3;42 ratio? If not, would an aftermarket limited slip type of set up like a Powertrax be compatible? Or just swap my ring to a pull a part G80? I am trying to be able to keep from changing out my front differential. If I did convert the rear end to the G80 and was able to keep my 3;42 gearing would I have to recalibrate the PCM for the G80 differential or the limited slip type of modification?
I'm aware that if I can just swap out my ring to keep my existing ratio, that it's a fairly complicated procedure to set up correctly so would take to a differential shop for the set up.
Thanks for any input all. Cam
8,143
G80 G42 axles are plenty out there. My Envoy has one. Its a direct swap, no computer calibration needed.
Yes they did. My 02 EXT had one in a 8.6". You can swap one of those in without any other modifications at all. Would be more reliable than the stock 8.0".
4,029
Yes, I put one in my 02 years ago. Was still going strong when I got rid of it last year.
c good
541
Was the EXT the only model with the 8.6"? Or did the Standard also come with an 8.6" depending on the build?
c good
541
What about the PowerTrax type of upgrades as opposed to a GM G80 Axle swap?
5.3 V8 got them too but are harder to locate compared to EXT/XL. Your 02 can use a diff from any year. The ones from 06 to 09 will have extra sensors at the tube ends for ABS but you can leave them disconnected.
seeridhanoa
