Finally Found That Sound
Code Red
377
So for awhile now I've been hearing a rattle on the TB, a while back I tookit to the dealer and they said it was either my end links or my spare tire holder.
Nope it looks like its the ebrake setup in the rotor assembly
Could very well be possible. The small clip that holds the shoe has a tendency of rusting away. Getting a replacement can be a PITA though and the stealership wants $$$ for them. Some brake shoe kits come with them. Had a hard time finding some for my Jimmy. Another possibility is the friction material comes unglued from the shoe. These parking brakes are lame and troublesome. I like the ones with the ratchet screw lever in the caliper piston, using the same pads against the rotor. Would actually work as an emergency brake. Our Montana van has these, no problem at all.
Code Red
377
Well it's going back to the dealer Monday since I have a extended warranty that should cover this.
McGMT
621
I realllly doubt they will cover that under the ext warranty, it more or less comes under the category of "consumable". Never know, could be a part of the linkage but more than likely its the pad or that clip as was mentioned. You would be surprised too, the shoe in there can wear down to nothing, I have seen that alot, even though you would think it would not wear as it just holds the vehicle still, they do wear down quite alot.
Code Red
377
you were right,they said it needs a ebrake kit and new shoes, they also said it needed a dust dust shield and they wanted $600, no thanks lol. However they did find a issue with my front diff seal and they are fixing it under warranty.
The dust shield is not a necessary piece. Doesn't really shield much really. E-brake shoes are fairly easy to replace. Just get a kit with the clips included.
McGMT
621
If you give the new parts a coat of anti seize it will slow down the rot... Not forever but at least it will last a little longer than normal...
Code Red
377
found out the front diff job would be 1300 if it wasnt for the warranty
McGMT
621
yea, the bills rack up quick on a front diff like these... Probably wouldve cost about 50 bucks if you did it yourself though lol.... 99% is labor... Did they say what seal went?
Code Red
377
not yet, but at least i wont have to, and it only costs me my warranty deductible of 100
Code Red
377
here is what the dealer said about the brakes, and the front diff on the TB
fhenninger
