I have a million irons in the fire right now and one of them is the water pump which I have successfully put in and I know it makes sense to do the fan clutch and water pump together. Fan does act up so I know it's not working right.
What I am trying to learn is not necessarily how the fan works with the fluid inside and temperature etc. I'm trying to understand the basic assembly. Are they ever assembled poorly where I need to tighten something? I plan on getting a new fan clutch but I'm trying to understand what this piece of it is so I know what's happening to my replacement if it were to happen again.
I have no movement at the pulley or the water pump. Handled that. I have attached a photo with an arrow pointing to where I have movement when I grab the fan blades and move up and down or left to right, not referring to spinning movement. It's like the whole clutch is loose on the shaft or isn't attached/secured to the shaft properly but that's my uneducated way of explaining it. Nut is secure to water pump. No play beyond nut. All movement at clutch.
Is that something that is supposed to be tightened inside somewhere? I don't have the bearing noise I'm reading everywhere on the internet. Maybe it's soon to follow if I were to drive it.
