Engine Swapping Made Un-Easy
jakster918
69
Oklahoma
Sounds like a classic bad vacuum leak.
Check your air intake hose to plenum
Check your pcv line
Check your brake booster line
Check your map sensor
Check your fuel return line
It's none of those other things you mentione
Ok brother, i will check those at daylight, ty so much....would a crack in the intake manifold cause that as well? ;ike a hairline crack? or naw
Check the intake manifold. Maybe it's a gasket or is loose? Also check for codes.
Reactions: movietvet
8,166
Come on man.. Couple days... Need a report!
m3talc0re
