Gonna change the cat..clear codes..see what happens then go into the valve body if the trans code comes back
You seem to have an extra resonator in your exhaust that I don't have. I have just pipe from the cat to the rear axle and then the muffler behind the axle.
That's actually the muffler between the cat and rear axle, then that's the resonator at the tailpipe. Yours must be loud with just a resonator.
isnt it supposed to be way hotter after cat
would move but pedal to floor no acceleration..like its only moving on idle power..
And that's the stall of the converter, also it drives away fine in 2nd.
So that sounds like the code he got is right, it's starting off in 4th gear when the shifter is in D. The result of a solenoid B stuck OFF?
