Disable side mirror position memory
CajunWon
137
Cary, NC
Need to find the wiring diagram which describes which wires control presets on the driver side-view mirror. Intend to cut these wires. Do not want to disable manual control of these mirrors using the door control.
When either the remote unlock or using the door preset #1 or #2, the drivers mirror behaves erratically ending up in the most downward position. Rather inconvenient to manually adjust this mirror with each use of the remote fob to unlock doors. The short-term remedy is to leave the fob at home & only use key entry.
2006 GMC Envoy Denali
Reprise
2,724
The service manuals are on this site; I can't link for you, as I'm typing this via phone - but an easy way to locate them is to find any post by @Mooseman - he has the link in his sig. Wiring diagrams included.
Now for the bad news...
If you cut any of the wires to the mirror, you will lose the power adjustment, the heater, or both (plus the turn signal, if you have them in the mirror housing.
It's not a separate wire(s) that control the memory feature, but a module that stores that, plus seat positon, etc., etc.
If you find different, let us know; I've been using my key for entry since I bought my Envoy over 2ys now. AFAIK, it's a bug for which there is no workaround except using the key to unlock with (locking w/ the fob is ok, for me at least.) Doesn't affect every owner, but it's not unheard of - you and I certainly aren't the only ones w/ the problem.
You might try using the power lock button instead of the fob. I do this because of the delay feature, and on the rare occasions where I do use the fob to unlock (as I did last night, loading via liftgate), about half the time, my mirrors don't move.
That suggests to me that there is *some* set of conditions that will trigger the bug (or not) - but no one has found it, that I know of. I know I haven't.
On edit: Actually, I did find something just now regarding this. It's on 'the other site' (aka: that which will not be named here).
It looks like there's a 'real' fix (which will be expensive, depending on how far you have to go), and a '10 cent' (permanent) workaround, which is to disable the seat / mirror repositioning in the DIC when the vehicle is unlocked. See: here
I'll try the 'cheap' fix, which will work fine for me, as I'm the only one who drives my truck. If others drive yours - besides disabling the automatic sync, the new driver will likely need to push '1' or '2' on the door button, as well.
CajunWon
137
Cary, NC
Disabled Seat Memory. Does not list anything about mirrors but Seat Memory may include mirror memory as this seems to work with the fob. Pressing #1 on the door still sends the mirror into wacky mode.
Matt
4,025
You need to disable easy seat exit, curb view and seat memory. If you can't live without those 3 things then you'll have to deal with wonky mirrors.
scottyreed6819
