Matt Original poster Member Dec 2, 2011 4,024 Jul 16, 2014 #1 Any chance of getting this http://gmtnation.com/content/how-replace-passenger-cv-shaft-115/ article linked again...I'm gonna need it in the next week or so. Thanks! Matt
PProph Member Dec 7, 2011 220 Jul 16, 2014 #2 Is it not this one: http://gmtnation.com/forums/topic/150-how-to-replace-passenger-cv-shaft-with-pictures/ Although the pics in this one are bad links. Upvote 0
Matt Original poster Member Dec 2, 2011 4,024 Jul 16, 2014 #3 That's probably it...I do well with photo's though. Thanks! Upvote 0
Hypnotoad Member Dec 5, 2011 1,584 Jul 16, 2014 #4 This write up will get you 90% of the way. Once you get to the CV Shaft, it pulls out. Mine didn't pull out easy at all. I had to crawl under and pry at it from the bottom of the truck. http://gmtnation.com/forums/index.php?/topic/4920-How-to:-Replace-front-wheel-hubs-and-upper-ball-joints. Reactions: Matt Upvote 0
Hypnotoad Member Dec 5, 2011 1,584 Jul 17, 2014 #6 Good luck with the repair. Reactions: Matt Upvote 0
