- Apr 10, 2012
- 26
My 2007 trailblazer 97,xxx miles daily driver I noticed the temp a little past 210 degrees. Should I just drain and refill or flush the cooling system?
808trailblazer said:My 2007 trailblazer 97,xxx miles daily driver I noticed the temp a little past 210 degrees. Should I just drain and refill or flush the cooling system?
AbsoluteZero said:If his 2007 has never had a coolant change he's a couple years past due. Probably overdue regardless if he's having a cooling problem. The published extended life coolant generally is 5 years or 150,000 miles.
AbsoluteZero said:The published extended life coolant generally is 5 years or 150,000 miles.
Playsinsnow said:For a few bucks you can get a coolant tester that will give you an idea of your approximate protection temps. Personally I would just do it before 100k because fluids do have a shelf life and 6 years running is a long time. The tester helps when you refill it too. Peace of mind
Playsinsnow said:Please be smart about adding coolant to water jugs. They can look like juice and smell sweet to dogs and children. I use the empty jugs to transport old coolant to the hazmat disposal place.
jes1888 said:I need to do the coolant flush on my 2006 because the thermostat is going bad, i bought the 2 hoses that go to the rad, the coolant sensor, thermostat of course, new rad cap and 2 jugs of prestone dex cool 50/50 ready to go in. My 06 I6 with 107xxx miles has never been flushed, i already put it on jacks, removed the lower hose from rad, and already drained the system. Question is, what goes next? Do i remove/clean the coolant canister 1st? or do i put filtered water on the system now with the remaining coolant on the canister or what? Sorry for the noob questions, I havent done this before and i want to do it right so please dont flame. Thanks in advance
strat81 said:If the coolant that was in the system looked good, what I would do is:
1) Exchange the 50/50 for concentrate
2) Fill the system with distilled water
3) Circulate the distilled water, burp the system, then drain it
4) Siphon out the contents of the expansion tank
5) Fill system with concentrate
Adding 50/50 to a system that is partially full will result in a weak mix. This is not good for resistance to freezing (not an issue in PR, probably), but weak coolant also does not the necessary amount of corrosion inhibitors. 50/50 is a good compromise for most climates, with 30% Dexcool being the recommended minimum and 70% Dexcool the maximum.
jes1888 said:Well, the coolant was almost like used oil color, dark brown, so i dont consider it good, i wanted to do a full flush, or something comparable. Here'e a pic of the color around the system. I was also planning to remove, empty and clean the plastic canister. My question is if i empty and clean the plastic container 1st and then put water or what? Also what do you mean by "burp" the system?
strat81 said:That doesn't look right. It looks like motor oil contamination.
You could try a garden hose flush, but that will leave a lot of tap water in the block. Some tap water is very high in minerals which can lead to scale and crud formation inside the cooling system.
If you remove and clean the expansion tank, fill it with coolant, not water.
Burping the system means to remove air from the cooling system. When you refill the radiator, you'll find it won't take very much on your first try. That is because of air trapped in the system. As the coolant circulates, the air will "burp" out of the system, allowing you to add more. If you fill the system and go for a drive, if you see the coolant gauge swing from cold to hot to cold to hot, that means there's air in the system.
What prompted you to service the cooling system? What does your engine oil look like?
strat81 said:The reason for flushing is that a substantial amount of coolant remains in the block when you pull the lower hose.
CaptainXL said:There is no such thing as a flush with the 4.2. The thermostat is the lowest point in the cooling circuit for the block. So when you remove the thermostat it all comes out. Let's not make this complicated.
Below the black line is below the cylinder water jack and even with the bottom of the water pump.
jes1888 said:If the water pump is a go, which brand according to experience works the best? I was looking the though one on advance auto parts, and reviews are good, but i trust more this forums than reviews so, keep the replies coming! Thanks in advance
edit: also please somebody tell me how to remove the freaking CTS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Mine has it on the passenger side at the farthest part of the block, on top of manifold and i didnt saw any possible way to remove it, especially with the heater hoses in the way! Thanks again
strat81 said:Almost 100k miles
jes1888 said:You sir, are wrong. I have 107K so im beyond that point. I can get the one on advance auto parts like for 25-30 dollars i think, so if it's good i'll take it, but that AC Delco also sounds at a great price. Where have you seen it at that price? Is the AC Delco the OEM one?
IllogicTC said:AC Delco is the OEM, or the closest you'll likely get to OEM. A lot of other "touchy" things on this engine work just fine when using AC Delco parts, it's like it knows
I myself don't think the water pump has any particular useful service life that can be defined in miles. Some people do the "pump with timing belt," and that's because their timing belt runs their water pump and it may as well all be done in one shot. For external units, it's one's own choice to swap out a known working pump. A pump can last a few miles if there's a defect, or it could end up lasting 200,000 miles of service. It's too hard to tell because operating conditions (heat of the coolant, current spinning rate, etc.) are so darned variable.
If you have the money and the means and want to do it, why not? Then you'd have a spare sitting on the shelf just in case, and a nice brand new one installed, and have the experience on how to do such work then.
strat81 said:Doh! I looked at the original post in the thread for my mileage number. But you're not the original poster.
Amazon lists the AC Delco 252-822 water pump for $37.88.
ETA: The comments for that part indicate that you should also get gasket 251-2029 from AC Delco as the one included with the pump is junk. YMMV.
Sparky said:For what it is worth I have 196K miles on my truck and it still has the original water pump in it.
And original tstat and sensor... don't know how, but it does! lol not complaining either!
If I had to do a flush I'd be tempted to buy a new tstat, and then just knock the actual tstat out of the old housing to use for flushing.
jes1888 said:So today is a new day!! Yesterday i drained, replaced thermostat and hoses. Today I'll clean the plastic canister and see if i can remove the coolant sensor after this, will mount everything back on and put filtered water on the system, let it run, and drain it, repeat until clean, then put in the 50/50 mix dexcool right. Decided to wait till this water pump fails and not buy a new one yet. If i'm doing something wrong, any corrections or anything will be well received. What's the difference between the concentrated and 50/50 dexcool?? I know that it's a mix and all but, my doubt comes because here in PR, the coolest temperature i see at night is no less than 66° So i dont need the "antifreeze" section of the coolant. Me, instead of buying coolant on shops or whatever, i go to a cooling service shop and refill my old containers for $5. The guy uses that on his repairs. He told me the coolant, at least here, it's not needed. So it still contains the anti rust, cleansing agents, whatever the "coolant" contains and good to go. To all my other cars, they've never failed yet, so that's good i guess. Somebody shed some light on this. Thanks!!
CaptainXL said:Why would you remove the tstat out of the housing? Are you afraid it will overheat with just distilled water in it or something? You still have the radiator and fan and the 15 PSI cap which lowers the boiling point. Antifreeze is mainly just that, to protect your engine from turning into a block of ice. If your considering flushing this way then let the coolant heat up all the way to 210 and then let it run some more so the hot water gets into the radiator. Otherwise if you remove the tstat from the housing it will take forever to heat up, if ever.
strat81 said:I believe he means he's only removing the t-stat temporarily for flushing purposes. It's faster/easier to circulate coolant without the t-stat in place. Once the system has been flushed, a new t-stat is installed and proper coolant is added and the system burped.
CaptainXL said:On a side note... since we are on the subject of cooling.
If you want to be thorough you can remove the grill and spray some coil cleaner on the radiator. Let it soak and rinse gently. preferably from behind where the fan is.
fadyasha who is in Saudi Arabia had a huge buildup of sand in his fins which was causing a bit higher temps.
Just a thought.
