I was on the way home through the highway today and something weird happened to my automatic transmission Chevy Colorado (2017) 2.8 diesel.
Since the vehicle does have deep stick for ATFs, I crawled under the vehicle , removed the transmission fill cap, insert a piece of paper towel and I believe there are still ATF fluid, though its light brown in color.
The vehicle has about 105k KM / 65k Miles on the odometer. The rear axle fluid has also been changed.
The engine oil/filter is frequently changed along with the fuel , air and cabin filter.
The coolant has also been flushed and changed 2 years ago.
I have never changed the transmission fluid (since the manual states, it has "lifetime transmission fluid") but I am planning to change the ATF soon.
Will Lucas Antislip work?
- I believe I was shifting between gear 3-4 (approx 60KM/h). And the car was hesitant to shift (the RPM was fluctuating between 1500 to 2300 rpm, (i did not force the car to shift up) ,therefore I turned the hazard lights on and moved to the "slower, 3rd lane" lane. I was assuming the gear was slipping between gear between 3 - 4
- I was looking at the side mirror and I saw "white smoke" during the incident above. Also there was a soft "grinding" noise during the incident above.
- I got off the highway to stop in order to smell the exhaust. The smell was ordinary, soot smell.
