So I have had a vibration in my front end for a couple months. It seems to come on just above 70mph.
I have replaced quite a bit in my front end already, in the last 3 weeks, tie rods, ball joints upper and lower, control arms upper and lower, front brake rotors, front brake pads, and all tires (Michelin Defender LTX M/S). Also have had an alignment, and 4 wheel balance. They were all needing replacement, not just throwing parts at it.. However, the vibration continues. I cant pin-point where exactly the vibration is.
I am just looking for suggestions. There really isnt much left to replace, rear axle rebuild, driveshaft u-joints front or rear, cv axles, and I think thats about it.
I have only been using 2wd as of the last year. 4wd shifts in an out perfectly. I have visually checked the rear driveshaft, and the U-Joints look to be good, but they are factory originals, at 195k miles. Same goes for the CV Axles. Wheel bearings were replaced last year, and have maybe 2k miles on them.
The only thing I can note is that when I was working on the rear end, the drivers side half shaft had no play, in or out, up or down. The passenger side -did- have play in and out, but not up or down.
