Changing Belts, Tensioners Rainier 5.3L
iceflow
5
Folks,
I've done timing belts, serpentine belts etc in the past so am reasonably clued in.....but am about to pull both belts and associated pulleys / tensioners off the Rainier, have not done this job on this vehicle before? From what I can gather the tensioner assy's have a dimple or notch that mates up to the block so they can be installed in the correct position. It all sounds pretty straightforward....but I'm never too proud to ask. :smile:
Thanks
RayVoy
939
Yep, pretty straight forward.
But just a little info, I think there is only one tensioner and the idler is usually the pulley that fails.
iceflow
5
Appreciate it, thanks. I did find on you tube some videos from a company called 1A Auto. For anyone interested search under V8, Tahoe, Envoy Serpentine belt and you should see hits on both a/c and serp belt swaps and associated idlers and tensioners. It looks straightforward, so will have at it when parts arrive.
Thanks
catfish520.na
