For Engine Builders... If you have to pull the Aluminum Engine Heads from any of the Cast Iron Block LS Engines... THIS Dude has some VERY Novel ways of cleaning the Piston Tops, Engine Decks and the Combustion Chambers of Aluminum Engine Heads in ways that are very clever in Protecting Things Inside of the Engine that are very worth knowing: Especially ...his "String Theory":
