- Aug 10, 2013
- 44
Alright ive had these noises and other problems since day one. First of all I got it cheap because the previous owners didnt maintain it and it had huge power loss, noises, and hvac bugs with only 60k.
I went ahead and bought it because the motor runs smooth, it shifts through the gears good, and there is no rust. Also theres a few in my family and a neighbor has one. all are perfect with over a 100k. Just wear items here and there.
The noises are sounds like tractor when cold, whining when under load, air or loud hissing noise thats coming from pass side (I think) while under load. Only the tractor like sound when in park or neutral.
What I've done to it has helped get the power back and I fixed the ac with actuators. But the noises remain. My mechanic says its normal, but he is wrong. I will not accept that. None of the other ones I know of make these noises.
I replaced.....
Water pump and both tensioners (all had wiggle)
Catalytic converter (plugged)
Both 02 sensors
E manifold gasket (loose and broken bolts) no cracks in manifold.
Thermostat and temp sensor (running at 170ish)
Tranny flush
Ive ran it without the belt and I'm pretty sure the whine was gone.I am going to do it again though. With the belt off everything was spinning smoothly. But I did find the wiggles and replaced those parts. Also the tractor and air sound just baffles me, I cant find exhaust leaks anywhere. I wonder if it takes a while for the manifold and cat gasket to break in?
Any help is greatly appreciated.
I replaced.....
Both 02 sensors
Tranny flush
