NEED HELP Cadillac Escalade ESV not open lifttage when off ignition
Mastery93
2
viet nam
Hello, I have a Cadillac Escalade ESV, everything works fine, the only problem is with the rear trunk. I cannot open the trunk with the remote when the key is off. it only works when i turn on the power key. I tried replacing another trunk control box and still having the same problem. I am trying to run the Liftgate control box program again but don't know which software can support the 2006 model. I have GDS2, GM PDS
7,741
Have you investigated whether or not THIS Feature is Activated and-or Set Up for you Cadillac Escalade? The Video nested in this Link is VERY Informative:
Anybody know if there's an RPO code for the power liftgate?
@Mastery93 , do you know for sure that your Escalade has a power liftgate? Have you seen it work before?
What interface are you using with the software? A Tech 2 with Tis2000 would be able to reprogram your module and access its functions. Maybe it's a problem with the module that controls the remote functions. If it was replaced, maybe it wasn't programmed for the power liftgate.
danfromutah
