C0055 code
Rizzoj2000
28
I have an 05 TB with 4.2 6 and getting c0055 code (rear speed sensor malfunction). Can anyone tell me where this is located? I appreciate any info. Thanks in advance.
Tailpiece of the transmission unless you have 4wd, in which case you have two of them on the rear of the transfer case. Be suspicious of the connector or the wiring before concluding it's a bad sensor.
djthumper
Administrator
Nov 20, 2011
14,950
North Las Vegas
It is part of the transmission output shaft.
Edit: man scooped by the_roadie
Rizzoj2000
28
Sorry about that. It's a 4wd. If not a wire problem, is it hard to change and Is there some way to test them it?
Fishermandude
