"Best In Show" Article on "How To R&R Blend Door Actuators on 1999-2006 GMT-800 Trucks & SUVs
7,782
This is a *Best In Show* Pictorial and Text Article on:
"How to R&R Blend Door Actuators in the 1999-2006 GMT-800 Trucks and SUVs with EXCELLENT Step-By-Steps":
NOTE:
If you wish to Save this Web Page as a PDF (IT IS TOO LARGE TO LINK HERE) Just Press and hold both the "CTRL" Button and the "P" Key on your Keyboard and select "PDF" as your destination and hit the "SAVE" Button. The Finished GMT-800 BDA R&R PDF will be about 20 Mbytes in Size when the DL has completed.
aisokdo
9
Nice
It let out snap and then turned to where it should have for the position i had adjusted it on the truck. I stuck it back in and it worked fine until I sold the truck years later.
snaptube vidmate
Fishermandude
