eutechnyx said:
Not that I don't want to take you guys advice on flushing but I just read too many horror stories of that on here and don't want to risk anything. The trans has about 110k and has probably never seen a new filter or fluid by the look of the fluid so I want to be careful. I'm unsure if the coolant is getting into the trans but I do know I've had the truck 2+ years and haven't even had to top off the coolant.
First of all let's get something straight this is my opinion only. I consider a flush when a machine is attached to the transmission cooling line and and fluid is forced through the system either forward or reverse. i consider it a change when the pan is dropped and the fluid is drained out. You can also use the gerotor pump to pump out the converter for a complete change, this will require at least 13 quarts to refill. I will never Flush the system, i will change the fluid and the filter by dropping/draining the pan. I will always change the filter whenever I change the fluid since this is where the contaminants are held and the filter is very low cost. It will also give you a chance to clean the mud from the pan and clean off the magnet so you start clean.
This is just my opinion of how I do things, other folks have their own opinions on both flushing, and a total change using the gerotor pump to evacuate the system, so be that. You will also get differing opinions of whether your transmission will self destruct after a fluid change. My opinion is that if you change it and it self destructs, it was on the way out anyway. I don't believe dirty fluid holds it together.
You are correct 110K is way overdue. Perhaps if you haven't had it since new it was done earlier, who knows. I would change the entire fluid and filter. If you want to run some clean fluid to FLUSH (god i hate that word) do it and then completely replace both the flushing fluid and the new filter you put in to flush with again new synthetic fluid and another new Filter. I personally use Amsoil fluid but any name brand synthetic should do.
By the way I also recommend a tranny cooler, even if you don't haul anything. All I have going for me is 40 years of this type of maintenance and several vehicles and NO tranny issues or replacements. Good luck I hope it all works out for you.
