Belt squeaking.
wagfam810
2
When my engine is warm and at idle my belt squeaks like crazy. While you are driving or at anytime when the engine is cold you don't get any noise from it. I have replaced the belt as it was getting worn but I have not done anything else to it. I would assume it is something wrong with the idler pulley but I my wife said I had to post on here before she would let me do anything to it. I have googled it and most people were saying to change the belt which I already have done. It is also not nearly as loud as the high pitched squeal that belts make when they are loose and cold.
Wooluf1952
2,663
Milwaukee, Wisconsin
Idler pulley, tensioner pulley, AC compressor and PS pump could all cause belt squeaking.
Remove the belt and spin each one.
Check for binding or a feeling of grit in the bearing.
djthumper
Administrator
Nov 20, 2011
14,950
North Las Vegas
I would bet the AC clutch bearing. Get a mechanics stethoscope and check that way
RayVoy
939
Or, the belt it'self
zenkick
