Just curious, why are you replacing the pan? Not a part that's replaced on a regular basis. And I would have gone with a used one instead. Cheaper and has the baffles. For the work involved, I wouldn't get one from a Pick-n-Pull but eBay has several.
The job was brought to my attention when my daughter's ex split and took her only working wheels. Her TrailBlazer had been parked for years with an oil pan leak and some 4WD issues that she didn't know anything about. He had tried to fix the leak with a JB Weld patch before they parked it, but that didn't work. I figured getting it back into service was her best option.
The more I looked, the less I liked. The entire front suspension was shot. And as it turns out, the drivetrain goes *through* the oil pan! WTF?! Then, looking around on YouTube, I saw that there are a *lot* of vids on patching these oil pans. Cool! I figured I'd give that a try, so I bought a die grinder and ground away the remnants of the half-assed patch job to expose the real nature of the leak.
Yikes! I found a long hairline crack that goes from the bottom, wraps up around the side and extends all the way to where the Intermediate Shaft Bearing Housing enters the side of the pan. It looks to me like the front right axle took such a massive shock that it cracked the oil pan where it supports the shaft bearings. Given that apparent likelihood, it suddenly made sense to me why there is a veritable smorgasbord of patched 4.2L Vortec oil pan vids on YouTube, and thus, you might understand why I wanted absolutely nothing to do with a used oil pan!
I decided to do the whole nine yards—oil pan, front suspension and front drivetrain; everything but the differential. And I'm still deciding if I want to replace the diff bearings, too. I'll get the seals out and have a good look at them...
The photo below shows what happened to the Intermediate Shaft Bearing Housing / 4WD Actuator assy when I tried to get it out of the pan. The hairline crack can be seen toward the upper left in the shiny, ground-away metal. It extends way left and wraps around the bottom corner.
I bought the new pan from an Amazon vendor for $157 including tax. Seems like a fine part, just no baffles. I think I'm going to try to reuse the old ones, maybe drill and tap the mounting posts...
