NEED HELP Bad fuel pump?
Fishnbob
45
OC
06 Saab 97x 5.3
Went to start today and it cranks, the acts like it starts then dies. Checked fuel pressure at rail, 50-52. Specs call for 55-62. I jacked up the driver side , got underneath and pounded the tank with a rubber mallet while wife cranked, no start no change. I don’t have a scanner just a code reader and no codes at all. Fuel pump or??
8,081
Do you have any lights on the dash after trying to start? Take pictures and post them.
8,081
No lights at all? Check engine? Oil? Security?
8,081
Do us a favor, with your Key On, but Engine Off, take a picture of your cluster, and post it.
There should be some sort of light on.. Thats why I would like to see a pic of it.
7,774
Probably NOT the Fuel Pump:
(1) Download, Save and Review THIS Video concerning the Location of the FUSE BOXES in the Saab 97-X and start this investigation by Systematically Checking EACH Fuse in each of those Fuse Box Locations and report back whatever you find in the way of Burned Out Fuses:
(2) You will need a Test Light to Test Each Fuse for continuity. Attach the Alligator Clamp of the Test Light to the Negative Battery Post (Black) and then TEST that it is working by touching the Steel Point of the Probe to the Positive Battery Post (RED) and ensure that the Light in the handle LIGHTS UP.
(3) Next, Visit each Fuse Box and after Pulling their Covers and reading there data on the INSIDE ...systematically probe the Tiny Metal Depressions on BOTH sides of each and every Fuse... WITHOUT PULLING THEM OUT OF THE FUSE BLOCK INSERT LOCATIONS TO DO SO.
(4) If the Test Lamp Lights UP on one side but Does NOT Light Up on the other... Continue to Poke at the Small Contact Points a few more times to ensure good contact with the Pin Probe. Then... PULL OUT THE SUSPECT FUSE and Eyeball the condition of the Hidden Filament inside by holding it up to a Light.
(5) If the Soft Metal Element inside has MELTED... Make a Note of that Fuse Color, its Marked Amperage Limit and its Numbered Location inside of the Fuse Box and its Identity Acronym from the Fuse Box Chart. Follow the Directions given in THIS Video:
Then... Come back here and tell us what you have found out...
The Circuit Continuity Test Probe Lights are available at AutoZone, eBay and Amazon from various vendors... any Basic Test Lamp Probe like THIS One ...will do:
Could be the ignition switch however the Saab doesn't have the traditional GM truck switch but a variant of the in dash one like the old Impala with the chipped key and PassKey 3. However having the key at RUN should still produce the lights in the cluster.
Just keep this difference in switches and security systems in mind.
7,774
Different Saab 9-3 Here ..BUT.... THIS Video is worth Noting only if the 9-7X has a similar PCM to ABS Harness Issue...JUST IN CASE they are the SAME ABS Brain Set UP:
TJBaker57
2,907
Colorado
I have to verify this but I believe that even if the cluster is totally without power, as long as the ground is intact, the CEL will turn on when the PCM activates it.
So with the key in RUN and engine OFF the CEL should be on.
Fishnbob
45
OC
Alright I but the bullet and took it to my Technician for diagnosis. Ends up a blown head gasket. Plugs are wet. Glad I had a real tech do this diagnosis or I’d be chasing my tail. Now another question, is this motor a DOD?? I’m gonna do the job myself as my tech said I could do it just to make sure to take heads to his referral for leveling in case of any warpage.
  • Wow
Geez, who would have thought? Yes, it's a DOD engine so if pulling the heads, it would be a good idea to do a DOD delete at the same time and get it tuned.
Fishnbob
45
OC
In California so can’t do the tune unfortunately. But is doing this job on a DOD make it any harder?
7,774
Mostly... On Your WALLET... for the DOD Delete Kit (ROLLER CAMSHAFT NOT INCLUDED) and for the Cost of having the Engine Heads Examined for Warps, Cracks and for their Re-Build. Then... Perhaps the Challenge of Your Patience, the Attention to Details, the Preparation and the Wrenching Skill Set necessary to Do ALL of this RIGHT
For your particular LH6 Motor... Michigan Motorsports carries THIS Full DOD Delete Kit:
Does NOT Include the Replacement Roller Camshaft!
CompCam DOD Delete Kit R&R:
And from Scoggin-Dickey.... Their DOD Delete 101 Kit and R&R Video Advice:
And Two More just to provide some looks at ALL of The Work Involved:
Last But Not Least...You'll need some Help with getting the DOD Feature deleted from the PCM as well. Consult here with @limequat and-or @Kelly@PCMofNC for this Service.
Reactions: Fishnbob
8,081
Yes you can.. Just need to find someone with HP tuners, and turn off the AFM/DOD in the factory tune. Since you are turning something off in the factory tune, and not altering any parameter's of the OEM tune, its completely legal.
Since you are going to be rebuilding the top end of the engine, you could also send out the PCM/TCM to @limequat and he can tune it out.
I am in Colorado, and although we dont have the Commyfornia emissions, we are only 1 step behind. And I tuned mine with @limequat , and passed emissions.
Reactions: Fishnbob
Maybe not. I have read the CA has started checking the checksum of the original tunes and if they don't equate, fail. If you can't do a tune, you can't delete.
Then, I would suggest that you just replace all the stock lifters, including the DOD lifters, and the trays, keep the original cam and use a Range DOD/AFM disabler. It just plugs into the OBD port and when it's time to get smog tested, pull it out. No evidence left behind and all works as it should.
Reactions: azswiss
Fishnbob
45
OC
Thanks! I talked to my tech today and he thinks I can do it so I’m gonna go for it
Fishnbob
45
OC
Okay so I’ve torn all down and heads are at the shop. Question is, lifters look alright but if I get the Range disabler do I need to replace all lifters with non AFM/DOD??
No. The Range is just to temporarily disable DOD. All of its components have to be present to have it functional at smog test time and prevent setting codes. I would replace all the lifters as they can fail regardless but that is your choice to reuse the old ones.
kraymates
