!!!!Salutations Wrenching Family!!!!
In my recent days of extreme review,
it has been my pleasure to quest for:
mechanical grasp of this timing system.
The data set is exceedingly vast, and the methodology is surgically acute.
It is my desire here to synthesize & exact a list of -panoramic steps-.
The scrupulous invulnerability of this meticulous approach is given in full view of the drastic profundity of this procedure.
________________________________________________________________________________________
1/11/2023: 4.2L LL8 Timing: Rigorous Mechanical Practicum Methodology Update
-A.- ACCESS ZONE:
INITIAL STEPS
1. *Complete All RATIOCINATIVE steps in pre-cleaning outer Engine Case & removal of Camshaft Cover.*
(If -In Vehicle-, All Accessories, Radiator, A/C Condenser, Hood and Front End Removal *Should* Be Anticipated)
2. Remove all spark plugs.
3. Approximate engine clockwise, observing Cyl. #4 for TDC approach & zenith: 1-5-3-6-2-4 = #1 TDC = NEXT.
4. Observe Cyl. #1 approaching TDC, install TDC indicator to Cyl.#1, install Dial Gauge above TDC indicator.
5. Continue rotation towards zenith @ circa 23 mm of *TOTAL* TDC plunger travel expression.
6. Begin scribe index of orientation relationship degree marks with harmonic balancer pulley outer lip & front cover.
7. Confirm, note TDC zenith degree, record mm @ calipers, rotate past this point until TDC plunger fully retracts.
8. Remove the dial gauge & TDC indicator, complete 13&1/2 rotations of the engine, reinstall TDC indicator&dial gauge.
9. Observe absolute zenith @ cylinder #1 TDC, remove dial gauge.
10. *If In-Vehicle* : place J44226-3 @ oil pan access hole to flex plate bolt.
11. *If On-Stand* : restrain flywheel orientation braced opposing *counterclockwise* rotation.
12. Mark relationships of camshaft sprockets to chain.
13. Complete the counterclockwise removal of the harmonic balancer bolt.
***THIS BOLT MOST LIKELY WILL REQUIRE A SERIES OF 4LB SLEDGE HAMMER SHOCKS WITH A BLIND PUNCH***
***THIS 24MM FITTING WILL REQUIRE DEAD LOAD PATIENCE, AND POTENTIALLY 4 FT. OF ADDED LEVERAGE ON A 3/4" RATCHET***
***IF ON STAND, THE ENGINE BRACKET REQUIRES FALSEWORK RESTRAINT BRACE AGAINST THE SLAB***
***AT EVERY *CRACK* OF THIS TTY FASTENER, HAULT THE LEVERAGE LOAD & ***
***DELIVER FURTHER *DIRECT* SHOCKS AT THE CENTER OF HEAD OF THE FASTENER***
14. Complete the removal of the harmonic balancer pulley & front cover oil seal.
15. Mark Oil Pump Gear Orientation.
-FOR COMPLETE ACCESS TO THE TIMING SYSTEM, THE OIL PAN *MUST* BE REMOVED-
16. *If On-Stand* : Invert the engine orientation for ease of removal.
16. *If In-Vehicle*: remove the J44226-3, break all oil pan bolts loose, back off fasteners halfway or less.
17. Gently tap the oil cover if necessary to aid in breaking the RTV bead, use caution not to pry excessively.
18. Use jackscrew locations provided to begin separating the pan from the block, allowing for the fasteners to "catch the pan".
19. Template Fasteners, Remove the oil pan, shim pan if necessary - no heavy leverage angle/eccentric force to pan edges.
(RECOMMENDED PURCHASE OF NEW OIL PAN FOR EXPEDIENCY)
******************UNBOLT THE OIL PUMP PICKUP TUBE **********************************
********FROM THE CRANKSHAFT CRADLE/OIL PUMP RELATIONSHIP*********************
(RECOMMENDED PURCHASE OF MELLING PICKUP TUBE)
********************DO NOT SCORE THE PICKUP TUBE DECK********************************
*If In-Vehicle* : Replace J44226-3 @ flex plate bolt& or 15mm to starter port&shim accordingly.
-Reset Engine In Plan View Orientation-
-MARK FRONT COVER RELATIONSHIP TO BLOCK-
20. Removing front cover center bolt first, template remaining fasteners and note condition. All reused threads require cleaning.
(RECOMMENDED PURCHASE OF *NEW FRONT COVER BOLTS/INNER SPACER BOLT* & *NEW FRONT COVER* FOR EXPEDIENCY)
21. Using jackscrew locations, introduce cover fasteners, allow time between jackscrew turns, -gently- pry case @ given overlaps.
22. Remove the cover forwards without tilt, crankshaft sprocket mandates straight line forward removal.
COMPLETE TIMING SYSTEM ACCESS HAS BEEN ACHIEVED.
-A.- ACCESS ZONE:
INITIAL STEPS
