- Jul 6, 2014
- 9,265
So, I've been chasing down this issue for well over a year and a half now, I have a random stall out, when it's hot out more so, that I can't catch with my scanner... (long story) The following is a list of items replaced or checked:
Throttle body cleaned
O2 sensor replaced, code for heater circuit and it was very lazy.
Cam sensor, It failed the tap test as per May03lt's video.
CPAS, had a ton of oil in the connector
Coil pack, because it died...
Tightened the bolts on the intake
Fuel pump, it also died
Fuel tank pressure sensor, it failed on the envoy so I was parts swapping until my check engine light came on.
So basically I am now looking more towards an intermittent connection, maybe a sensor. Now I had said earlier that I was thinking a throttle sensor, here is why. A friend of a friend had a trailblazer, this man was a gm tech, that was doing the same thing, what he did was he drove around with the tech 2 until he caught it, well it ended up being the tps. But this was an ss, so I'd imagine the whole thing is different, but it was a starting point so I have been data logging tac data. At idle voltage according to the dash is 14... torque says 12.8, meter on the battery says 13.7-13.9. Any input on things to check would be much appreciated.
