Alarm impact sensor
GregT
58
So what are you guys setting your impact sensor at. I'm thinking sensitive may be too much for now. I gave my trailblazer a good shake and a bump and didn't do anything. I believe I should turn up the sensitivity. I want to be alerted if someone hits it. Now I don't think it will. I had this professionally installed I will have to open up under the dash and see how good of a job they did. I might do some wire tucking. :eek:
MAY03LT
Delmarva
Before you adjust the sensitivity, check the mounting location of the sensor. The sensor should be mounted to a rigid surface, if it's just taped to the wire harness it won't be as effective.
GregT
58
Hmmm These guys did a good job too good the box is tucked up in there good. I didn't feel that ambitious. Not easy to get to at all. :undecided:
chriswilson5585
