NEED HELP Air vents, easy removal ??
fletch09
1,982
09 TB
is there an easy way to get these vents out w/o removing dash?
just want to turn them around (so that the side to side adjustment lever is in the upper half)
since the hands free law took effect July 1 in Illinois, have a cell phone holder that is vent mounted.
will work better if these get turned around.
Iirc, you can just pull on them.
Reactions: fletch09
Boricua SS
3,080
They can be popped out. Will take some persuasion but let me dig up some pix when I had mine out...20130515_180150.jpg20130515_175602.jpg
fletch09
1,982
thanks BoricuaSS!
i'm assuming (bottom pic) the tits on the side are what holds them in.
it appears by the position of those, that i would not be able to flip them so that the side to side adjustment would be in the upper half.
Boricua SS
3,080
Yup that's what holds them in place while we move them up and down. One side of the vent is an enclosed connection while the other is slightly open allowing you to slide it back into place
fhenninger
