Adding Driving lights
nospark
28
Hazelwood MO
Helo, I have '07 Tahoe LS without driving lights. Would the wiring harness be the the same for all packages to were I could simply replace headlight/4wd swith panel and add stock lamps in the holes for the lights. In other word could it be 'plug n play'? Thank you
IllogicTC
3,452
If the switch directly controls the lighting, yes, you'd just have to run some wire also and probably crimp on a different pigtail. It's likely though that those lights are controlled by the BCM, with the switch offering some sort of cancel. This makes it (in all practical terms) impossible unless you're willing to fork cash to the dealer for a BCM software change.
Dec 5, 2016
5
St.Louis
All you have to do is replace the switch with a unit that has the fog light option and install the front fog light wiring harness. The BCM does not require any type of reprogram. You will find more info on the fog lights set up on YouTube
You do realize you responded to a long dead thread?
Fishermandude
