I've had a Kicker ZR120 and (2) 10" CompVR subs in my Bravada for nearly 10 years. The amp has given me intermittent issues for years but I finally broke down and resoldered the daughterboard in it so the KickEQ card stops cutting out and shutting my amp down. Now it finally hits like it should. Cue my current problem.... no good music source. I got rid of all my CDs over the past several years (stupidly) and don't have any tapes. I've been using a tape adapter to hook a selection of MP3 players and phones. I even found a bluetooth tape adapter... a pretty slick piece of kit. It rocks, but I have to align it to the tape head every time I use it, it has a physical switch I have to turn on and off so it doesn't run the battery down, and it needs charged after 6 to 8 hours of use. I don't mind all these things when I've got a trip of any length.... but for quick trips to drop the kids off at school or to the grocery store, I don't even bother turning the stereo on. I live in radio hell... gospel, talk radio, and static are my only radio station choices... so I need a good solid music source. An additional complication is that even with aligning the tape adapters as best I can, regardless of which one I use or what settings I use the left side signal is always weak compared to the right.
So, I remembered that there have been many people who have added AUX ports to Delco head units over the years using various methods. It's infinitely easier to do so when you have a "band" or "source" button (which I don't have) because you can intercept the music signal coming in from an external source such as an XM tuner or CD Changer. I don't have that option. I found where people have successfully done so tapping into the signal wires INSIDE the head unit coming from the internal CD player. I figured the same must be possible for the internal tape player. I'm not a fan of altering how my head unit works with CDs in case I ever actually try to put one in it... but I'm totally down with altering the internal tape signal.
I've ordered a (4) pack of 5 pin Aux ports and will be picking up some CAT5e or CAT6 cable to do the wiring. What I could use some help with is if anyone knows WHICH wires inside the head unit I need to tap into to provide the audio signal. There are 2 pigtails that go to the internal tape player. I don't yet have photos but one pigtail has probably 9 or 10 wires and the other maybe 5 or 6. I'm 90% sure I need the 1st and 3rd pin (wire) of the 9 pin pigtail, but I don't know for sure. If anyone can clear it up, I would appreciate it. I've done extensive searches on multiple forums but I couldn't find anything that covers this specific scenario. Of course I could replace the head unit altogether and not worry about any of this, but I can't really justify pouring hundreds of dollars into a modern head unit for a vehicle that's 21 years old with 300,000+ miles on it. When I actually attempt the wiring and do the modifications I intend to take pictures and report results to hopefully contribute in some small way to this great site.
