- Aug 3, 2015
- 18
07 Trail Blazer with I-6 4.2 engine
Adding a cooler where I tow a 3000lb bass boat. I went to Autozone and picked up a Torqflo cooler rated medium. Going thru the instructions I noticed the cooler is mounted directly onto the radiator with zip ties that go thru both the cooler and radiator. Is this something new? I always thought you needed approx. 1 inch between the two for air flow? Anyone use this method or should I run from it!
Thanks
Thanks
