ABS light, replace sensor?
MoMobile
31
The ABS light has come on and a shop told me that the sensor need to be replaced. Is this something I can do on my own?
EDIT: it is a 2004 Envoy
NV7
2
Depending on your mechanical capability, yes. Which sensor did they say need to be replaced?
If its a front sensor I would recommend changing the entire hub. A new hub will come with a sensor and it will make the job easier.
MoMobile
31
I would consider my mechanical aptitude a 7 on a scale of 10 but for something like a hub replacement I would get a shop to do it although I've done it on my FWD car yearsss ago. Wouldn't the truck end a front end alignment if the hub was replaced?
djthumper
Administrator
Nov 20, 2011
14,950
North Las Vegas
Nope, it won't need a realignment. You are not replacing or removing ant suspension components.
NV7
2
Yep. Remove wheel, caliper and bracket and slide off the rotor. Remove the axle nut and the three beta holding the hub in and slide it off.
rikosintie
