- Apr 27, 2014
- 118
Good morning everyone,
I have a question about a couple of electrical issues.
Reciently, the radio will activate the '' searching for disk'' sound when sitting or moving or parked with the key on or off, with us in or out. At times it goes at night and if I dont drive it for several days I can find a dead battery. Also, if I hit a large enough BUMP, the radio will come on. Now, on to problem #2
The recirculate button seems to have a mind of its own. Most of the time it will not function, though once in a while, it will work, no rhyme or reason.
I have searched here for the recirc issue and it seems that the dash ground pack( thanks Roadie ) is suspect for a MULTITUDE of issues, including this one, I think. I do not think the actuator is at fault because when the light on the button "lights" , recirc comes on every time. I am aware that not all modes will recirc as well. I only try ricirc in dash vents only. I do not suspect the switch yet either because I may get a string of activiation sequences in a row, then nothing for a couple days. Its going into the DOG DAYS here with HIGH humidity and temps near 100 and it is SO much better when ricirc "works"
Any thoughts or comments are always welcomed
Thanks for the help,
Dave
Dave
