- Dec 12, 2011
- 4,656
Letting the engine idle for about 30 min, ambient temp is 78 deg, measure in front of the condenser.
I have at idle, 28 PSI / 175 PSI, if I rev the motor slightly the high will climb near 200 PSI then cycle off.
If I hold the RPM's at 2000 for a few min, cycling the compressor about 10 to 15 times it will stop working.
Light mist of water on compressor will turn it on again.
Edited to add, at idle the compressor stays on, only cycles if I raise the RPM. Doesn't seem to build pressure when idling, if so it's very very slow.
