4.2 problem
Topfueltommy69
1
Idaho
I have an 06 Trailblazer that came with the 4.2 originally. I put an 08 4.2 in it not knowing there was a reluctor ring difference. What can I do? Complete harness change? Screwed? Can someone help me with a correct answer to resolve this? Thank you.
Reprise
2,724
(on edit: Mods... if I'm totally off-base here (wrt accuracy)... just go ahead and remove my post. No sense confusing the guy. Thx.)
OP...
I'll preface this by saying I have the V8 in mine... but here's what I remember about the 4.2L model years... If I'm slightly wrong about this, someone will come along and correct me...
- '08 truck only interchanges with '08 engine (you already know why)
- '06-'07 interchange only with each other (I forget why, although I remember the cylinder head changed, but that in itself wouldn't be the reason)
- '02-'05 are basically interchangeable (might need to swap an accessory or two over, but otherwise doable).
So... how to fix, for you?
If you can't return / no '06-'07 engine available...
- You'd need a revised wiring harness, a 58x crank position sensor, and an '08 PCM, at a minimum
Or...
- You take out the '08 engine and swap reluctor rings (pretty sure they're like the V8; those can be swapped). Obviously, this means pulling the oil pan at a minimum, and likely removing the crank (the reluctor is a press-fit). A lot of work, especially if the crank gets removed.
You don't want to just throw the old '06 engine's crank in the '08 block (provided it's good). A lot of precision measurements need to be taken to ensure tolerances are good. A different bearing set might be needed (for sizing), and I'd probably put in new main / rod bearings anyway, even if you didn't have to use under- / oversized ones.
Possible to swap 'in-car' ? Maybe... *if* you don't have to remove the crank. If you do, then I'd rather take the engine out of the truck and put it on a stand. I wouldn't trust myself to R&R a crankshaft with the block in the truck. Maybe, with a second person under the truck with you, helping to lower / raise the crank into position without damaging it. That's a big 'maybe', though.
If the crossmember isn't removable, you have 4WD, etc., -- then it's gonna be easier to pull the engine (although the front driveshaft actually goes through a cutout in the oil pan on this truck, so you'll still be messing with the front diff to some extent).
If this is even possible, you'll most likely be moving the transmission back a bit to make room, as the torque converter attaches to the flexplate, which attaches to the crank. New bolts for the crank <> flexplate (with red loctite), as well as a new rear main seal.
I don't know how much clearance there is between the back end of the crank and the block (so that the reluctor can slip out from between.) Probably not enough.
TL; DR: It's 'fixable', but some pain will be involved, either way. Pick your poison.
Actually 08-09
Actually 02-07 will interchange where 06-07 have minor modifications. If really needed, an 02-05 motor can work in an 06-07
See above
That won't work. After 08, GM started integrating the new GMLAN whereas older vehicles were using the old CANBUS. The two won't talk to each other.
It's not just the reluctor ring, it's the entire crank. It's cast in there. It has been done but not easy. You would have to pull the engine. The 58x sensor will screw in the same hole. Someone else here had done it. If you do go this way, you'll likely need new bearings and a good crank. Will also need to check clearances.
If you can, you're better off swapping the whole engine. If a yard sold it to you as compatible to your 06, then you have leverage as it was their fault for selling you the wrong engine. If you grabbed it out of a pick-n-pull, check what their return policy is. Ours here has a 30 day return policy, no questions asked, but get a gift card or voucher.
Reactions: Dieseldog and mrrsm
Reprise
2,724
Moose -- given the corrections, I wouldn't have been offended if you'd just deleted my post, as I mentioned up top.
I had a feeling I shoulda stayed in my V8 lane... that seems to be confirmed, now :nono:
(thanks for the clarifications!) :biggrin:
8,075
There is a 58x to 24x converter on the market. but I think it only works on V8 motors..
At the end of the day, that motor is going to have to come out, and a 06/07 is going to have to go in.
The only other option is to replace every single wiring harness, pigtail, module, computer, EVERYTHING, from a donor truck.
Reactions: rchalmers3
8,075
After reading the thing for the converter, I dont see why it wouldnt work, as long as the plugs are the same. It would be interesting to try for sure!
rchalmers3
207
Irmo, SC
@Topfueltommy69 Have you made any decisions or actions?
I have a rebuilt, running 2006 engine that I'd be willing to sell and/or trade. But maybe you have already solved this issue or you are way out of my area.
Rick
8,075
I think he was a one post wonder. Has not been back since he posted his original thread.
Not even to see the replies.
BDD1982
2
athens, al
OP...
Or...
mooseman what exactly would you have to do when putting the 05 4.2 into 06 trailblazer to make it work
Extend the coolant temp sensor wires from the right rear side to the left front above the thermostat. The ignition coil connectors are the same.
BDD1982
2
athens, al
So everything else is ok as far as matching up. I’m running into the problem of not getting full power to everything in the ecm plug ins
7,770
Check out Post #6 in THIS Thread for the PCM (ECM) Pin-Outs and Class 2 Network Diagram, too:
Pretty sure they were all the same through all the years of the 4.2 run. The thing that did change was the internal and external of the cam phaser but the way the PCM controls it is the same using the same CPAS through all years.
7,770
I keep losing count half way around...
04envoyxlv8
