NEED HELP 2006 trailblazer no power/start
06tbrudy
4
Minnesota
New ignition control box good battery new altnator
Dome light on put key in turn no click no chimes no start no power at all try again multiple times after shutting n opening door mulptle times try key again sometimes it starts but is delayed ...HELPPPPPPP
7,773
When did you have all of THIS Stuff Installed?
Sub and amp 0 gauge ofc wire new Kenwood deck and 6.5 speakers
...and was it Professionally installed or...a DIY job?
Also... What if any Codes have shown up from your use of an OBD2 Code Reader?
06tbrudy
4
Minnesota
Po411 n po191....i installed myself I've been doing for 15 years never once messed up ... Was installed 6 months ago
7,773
If 'New ignition control box' means you just replaced the Ignition Switch underneath the Steering Column... This video from Eric "OH" at South Main Auto shows how to run down problems with Wire Diagnostics using a Tech 2 and a "Scope On A Rope" Light Probe for continuity testing in the Ignition Switch Wiring (even New Ones if they are NOT ACDelco Brand can go sideways):
...and another No Start No Crank Video from @MAY03LT...
4,656
Have you checked for voltage at the starter solenoid when you turn the key to Start?
You mean the ignition switch? Maybe it wasn't installed properly with the gears set right. There is a video on YT but I'm at work and can't access it right now.
Reactions: gmcman
7,773
As per @Mooseman...
How to Properly Align the Ignition Switch "Rack & Pinion" Gear Teeth between the ACDelco Ignition Switch...and the Key-Lock in the Steering Column during a Complete Switch R&R::
Gdub2306
