As an ex-mechanic (20 years ago) this vehicle has me stumped and I would appreciate any help. Wife drove car home fine, gets up next morning and car is running like crap. Used scan toll and got a P0300. Against my better training I started changing parts. First the plugs with new AC Iridium units, then all new coil packs, fuel filter (the old one had mud in it) and cam position sensor. Figured the fuel injectors might be full of crap. Pulled it all down and disassembled the fuel rail and injectors. Cleaned the rail and soaked the injectors and blew out with air pressure (there was crap in them). Reassembled all with new intake gaskets and changed valve cover gasket at the same time (noticed a little oil pooling in the plug wells). Now the fun part, tried to start and will crank but not run. Fuel pump does run, car smells like it might be flooding. It acts like it is trying to fire but just not quite there. Ran scan tool again but no codes. I NEED HELP PLEASE.
Forgot to mention that I removed and cleaned the throttle body.
