Hello, all. I have just rewired my (used) pop-up trailer for the 7-position circular connector on my Envoy. Everything is working perfectly, except for the 12V charging line for the trailer's battery. Turn signals & running lights are fine, so it is not a ground issue. I've measured the voltage at the 7-pin connector, and at the connector that actually plugs into the rear of the connector (behind the bumper) - 0V in both cases. I then opened up the fusebox under the hood and checked fuse 32, which tests fine, and I was able to measure 12V at the input side of this fuse's connector (the side furthest from the front of the vehicle). So, somewhere between the output post of the fuse and the connector on the rear of the truck, I have a broken line somewhere. Can anybody tell me how the harness that runs to the rear of the truck is routed (both on the underside of the truck's frame and inside the engine compartment) so that I can find the break?
Thanks,
-Chris
Thanks,
-Chris
