NEED HELP 06 Tahoe, No Start
JOSh%
1
Louisiana
I have a 2006 Tahoe, I just changed battery, and ignition switch. Finally figured out how to reset VATS truck ran good for a day. Now it won't start, VATS light goes off after a couple seconds turns over but wont start. After turning key to on position for the second time the VATS light flashes once and goes off. Please help
7,745
Suspect either an incomplete plug-in of the New Ignition Switch Module ... or perhaps the "Teeth" on the Switch have been "Mis-Timed". You could also have a Sketchy Key-In-Tumbler situation inside with the Lock-Work becoming Worn Out.
If your Key Chain has been laden with Extra Keys that have been acting like a Pendulum for years on end, this action of constantly swinging back and forth on the Ignition Key can eventually wear down or loosen the Internal Lock Work Mechanism.
As a result of all this internal wear, if an electrical contact with the Anti-Theft System is momentarily broken as you drive, it can trigger the Disabling or No Start event to occur.
If your Internal Tumbler and Lock Mechanism is Badly Worn, you can purchase a complete replacement set with a New, Unique Key for the Ignition. Follow THIS Video for replacing the Ignition after Properly Timing The Switch:
...and THIS Video will show you How to Re-Key your New Replacement Lock-Work to your Existing Manual Ignition Key(s):
Will you please elaborate on whatever it was (precisely) that you did in order to Disable your VATS?
Last but NOT Least, Eric "O" from SMA (South Main Auto) does SUCH a Good Job of going over the Ignition Switch Diagnostics using the Wiring Diagram for the Circuitry for a 2006 Chevrolet Silverado that Your Vehicle shares as well and knowing this information might help with further Ignition Switch Diagnostics:
Reactions: gmcman and Mooseman
danfromutah
