Has some trouble back in 2014 with crow hopping and binding due to a bad encoder motor. Many thanks again to all that helped with the troubleshooting and guidance! Just recently I started having the the same issues again, so with the prior experience leading me to the encoder motor I decided to replace it again which solved the issue, I thought. Everything was fine for a couple of weeks then it started again with the binding and whining while turning into the drive or in a parking space etc. I searched thru the topics again and decided to pull the #8 fuse and reset the TCCM and encoder which I thought had solved the problem but only for another couple weeks then it's back again... So looking over everything again and decided that the tires could possibly be causing me the trouble as they were worn and needed to be replaced. I had a new set put on but within a couple of days with the new tires I'm back to the same situation. Does anyone have some ideas or suggestions? All the fluids have been changed, new tires, tire pressure checked, new encoder motor, however I haven't check the transfer case fluid level, just happen to realize that...Also when I replaced the encoder motor I failed to remove the #8 fuse but would that be an issue? Anyway thanks in advance for any help!
