TOOL TRAY FOR TRAILBLAZERS
Petnatcar
79
Watertown, NY
Hi Guys,
I originally made this for a different vehicle but adapted it to fit the TB.
The size is 22" x 15". The blocks on the underside keep it from sliding around.
The 2 square blocks center over a couple of bolts and the other block fits between the shroud and
the front cross member.
Trace the arc of the shroud onto a piece of cardboard and transfer that to a board for the
arc over the shroud.
You have to cut a couple little notches in the front to clear the lever that opens the hood and a
small lip in the plastic on the grill that goes around the opening for the latch.
You may not be able to use it for every job but it helps keeps the tools in one place and
it's great for changing the spark plugs.
10,691
That's a pretty creative idea. Well done sir! :thumbsup:
jesussaves
