TIS2000
DTN1
2
SD
Looking for a TIS2000 download that'll work with Tech2Win on a tablet/laptop.
Want to try & flash BCM on 06 h3 Hummer as it failed with a B1000 & B1009 while doing a Passlock relearn with the 3 10 min relearns needed to learn the new Passlock in.
Any help would be greatly appreciated as we can't get the security light to go away.
IF there was a way to bypass it that I can download, physically do today I'd do it.
Only other way that I know of to bypass VATS is to have it turned off in the PCM tune.
DTN1
2
SD
It's a Passlock system. No pellet keys here. The key is the reverse Toyota key they make I know this because I do keys and looked up keys, system using repair link which shops, Indies can use for parts lookup, sourcing.
I have the Tech2Win software that came from someone else. I have the drew Tech CarDaq 3 plus which is activated. I may just go the programmed route with the B1009 Code as service information says if this code is present and active replace the BCM. Doesn't hurt nothing to try a flash and if module is deemed bad then I can just flash a used one in.
Joe Luster
