- Jul 24, 2012
- 827
Top brake light good. Running lights good, flashers good, backup lamps good. New lenses/circuit boards within 3 months. New LED lamps within 3 months.
Engine compartment fuse is good. Back seat fuse is good. Trailer brake lights are good. Wires into circuit boards look good. Circuit boards look good/no damage.
Did replace the flasher module with the new LEDs, and swapped in a donor steering column, a couple months ago, and swapped back in the turn signal stalk from the original column.
Checked operation on the tail lights after the lens/LED swap. Did I check after the flasher swap? Maybe? Should that part matter? Probably did not check tail lights after the steering column swap.
I don't know where in there they went out, just that they don't work now.
Watched some videos, didn't really get anywhere with those.
Thoughts?
Thoughts?
