Need help on Logo Decision.
TrailBlazer13
63
As many of you know i am an avid Storm Chaser. My Trailblazer is being turned into a Tornado Chase Vehicle slowly. I am starting up a youtube channel as well as getting some merchendise created. I need your help I have 3 Logos to choose from if you could please give me your Two Cents.
Thank you for the help. also if your a storm chaser let me know always looking to make connections.
djthumper
Administrator
Nov 20, 2011
14,955
North Las Vegas
The second with a different color lightening bolt, Even white will make it pop better.
Grimor
954
they all look like they will turn into a blob at small size. Some things I've always tried to keep in mind doing logos;
how will it look printed in B&W, 3 color, or 4 color
how will it look without half-tones or dithering
how will it look at 1"x1", 1'x1', and 10'x10'
Can it be embroidered
Is the font generally available or commercial
Is the text "text" or will it have to be rendered
TimRXUV777
189
I have done quite a bit of graphic design work in the engineering field. I would recommend making sure the unique elements in the logo are shades or tints enough different to make them easily distinguishable. I don't think you've succeeded fully in any of them in that regard. I would also say that the second or third logo accomplishes it probably the best. I like the shading in the funnel of the second but it should probably be circular to suggest the 3d dimensions that you can't show in 2d. I would suggest lightening up the funnel and maybe using white circular fill to imply the circular motion of the funnel. I would also change, as has been suggested earlier, the color of the lightning bolt if you do use the second example. I am also not sure about how you are showing the top of the funnel.. it could probably be simplified? Also the typefaces don't seem to relate well to the words but if you like them keep them as is.
jesussaves
