ABS pump
ghenny440
368
I have an abs light on on my 03 trailblazer with the 4.2 with 4 wheel drive it is the short wheel base, i had it scanned and have found it to have a C0267 code, pump motor circuit open. Had my mechanic look at it and he has a buddy with a high end snap on scan tool he used, and he got my mechanic the schematic for the pump to check all grounds. It came back the pump is bad as i already assumed this. So my question is when i order the new pump is there an RPO code i need to check on the glove box or just to make sure its one with or without traction control as my trailblazer does NOT have a traction control button.
All help is appreciated guys thanks in advance
TJBaker57
2,907
Colorado
Would you happen to know if this specific ground was checked? It has long been known to be trouble. There is even a TSB about it that recommends replacing the terminal and hardware. It is the primary ground for the pump.
Reactions: ghenny440
ghenny440
368
If that's the one under the drivers door, yes, removed the bolt(it broke) cleaned to bare metal like in the pic, drilled new hole added new nut and bolt to ground and sprayed battery spray(red battery grease in spray can) over it and checked continuity all was good.
Reactions: TJBaker57
I don't think there's anything special about the pump. They're the same from 02-05. Only 06+ have the traction control/Stabilitrak.
ghenny440
368
Thanks buddy! I wasnt sure havent even really known anyone at all that has had to replace one
romat
