Amazon Product A "One Over The World View " of Basic Welding Equipment...
7,857
Oh... For God's Sake... Let me just get ALL of this Gear covered ONCE AND FOR ALL... So I don't have to go over all of this STUFF... In "Piecemeal" over time:
These purchases span from as far back as 2017 right up to the Present. The Latest and Greatest of this Bunch is necessary so that I can FCAW outside in my 10' X 14' Elevated Arrow Shed out back and plug in a 40' Heavy AWG Wire Extension cord into my Garage Electric Dryer Outlet and safely handle Welding @ 220 Volts on the New Dual Voltage (Tiny, School Lunch Pale Sized) Yellow Hynade Welder. Here it is In Action:
I have some projects in need of Thicker Steel ...and Welding off of a 110 Volt Circuit suffering with Very Short Duty Cycles using my Old Green Forney will NOT give me the Penetration needed for Good Seam Bonding on some segments of this Thicker Steel.
Take note from all of the attached images that if you want to use your 240-300 Volt @ 30 Amp Dryer Plug-In Port... You will need the Heavy Gauge "Shorty" Yellow Colored Adapter Plug Ends-Cable shown below.
All of this equipment is just about what an Average, Basic Welder might want at His or Her disposal for General Shop Use and Farm or Light Industrial Repair. Note that having a requisite Self-Darkening Mask, Thick Leather Gloves, 100% Cotton Protective Clothing and other Ancillary Welder's Gear are NOT covered below... So Remember... NEVER, EVER WELD WITHOUT PROPER HAND, SKIN AND UV SPARKING EYE PROTECTION... I MEAN IT!:
Hynade Flux-Core Welder 110-220 VDC:
https://www.amazon.com/dp/B09GQS13VP/?tag=gmtnation-20
YESWELDER 240VDC WELDERS EXTENSION CORD:
https://www.amazon.com/dp/B08QJ8RCJ3/?tag=gmtnation-20
HZXVOGEN 240 VDC EXTENSION CORD TO DRYER OUTLET ADAPTER:
https://www.amazon.com/dp/B07Z4YFM7Z/?tag=gmtnation-20
Weldpro Multi Function 3 tier Welding Cart:
https://www.amazon.com/dp/B08G5CW3DY/?tag=gmtnation-20
YESWELDER Magnetic MIG Welding Torch Holder:​
https://www.amazon.com/dp/B091TLGSGN/?tag=gmtnation-20
Hobart 770074 Welding MIG Accessory Nozzle Gel:
https://www.amazon.com/dp/B0017Z5J1W/?tag=gmtnation-20
Hynade Flux Core Gas-less MIG Wire, Mild Steel E71TGS 0.030 ''2 lbs -MIG Torch Contact Tip For Mig Welding Torch:
https://www.amazon.com/dp/B0B7DKP3FX/?tag=gmtnation-20
Hynade Flux Core Gas-less MIG Wire, Mild Steel E71TGS 0.035' '2 lbs
https://www.amazon.com/dp/B09CHGN2V3/?tag=gmtnation-20
Forney Easy Weld 261, 140 FC-i Welder, 120V, Green:
https://www.amazon.com/Forney-Easy-Weld-261-Machine/dp/B07CP9CDVQ/ref=sr_1_4?crid=21MUMVO0J2429&keywords=forney%2Beasy%2Bweld%2B261%2C%2B140%2Bfc-i%2Bwelder%2C%2B120v%2C%2Bgreen&qid=1664180299&qu=eyJxc2MiOiIyLjA2IiwicXNhIjoiMS4zMiIsInFzcCI6IjEuMDcifQ%3D%3D&sprefix=forney%2Beasy%2Caps%2C136&sr=8-4&th=1
Forney 42300 Flux Core Mig Wire, Mild Steel E71TGS.030-Diameter, 2Lb Spool:
https://www.amazon.com/dp/B0009ZH7KW/?tag=gmtnation-20
KSEIBI 4 1/2 in Flap Disc Aluminum Oxide 10 Pack Auto Body Sanding Grinding Wheel (40 Grit) 686008:
https://www.amazon.com/dp/B073PRDSTP/?tag=gmtnation-20
Joe Luster
