93 gmc k1500 bump stop question
93gmcburban
12
groves texas
i installed a 3 inch torsion key lift kit with 3 inch blocks in rear. as well as the little metal pieces to add to the shocks so they were not out of travel range. the front looks like the upper a arm is resting on the metal part of the frame or the part holding the rubber bump stop. i need to know if that is something i could cut out so the upper a arm can travel little more downward when i hit bumps in road, a few times it has felt like the front tire has come off the ground bouncing off that part. would like to only cut the top lid portion off so rubber stop still there on the truck.i have included a picture and greatly appreciate all info i can get on this issue. you all have helped me before with a fuel issue. thank you again 20200604_202700.jpg
Joe Luster
