To start, I’m working on a 2008 9-7x 4.2i. I can’t get the passenger Halogen low beam headlight to work. New bulb, new HDM relay, good fuse. The driver’s side works fine. The condition is the same with DRL and lamps fully on. I don’t see broken wires, corrosion, or melting at the connectors. With a multimeter, I have voltage across either black wire to the green/black wire, and nothing if I test either black wire to the white wire. If I read the diagram correctly, the white wire is positive voltage for the low beam.
Any ideas?
Any ideas?
